Use the following commands to display KHI information about the performance of the switch.
  1. To enter User EXEC mode, log on to the switch.
  2. Display buffer performance and utilization statistics:
    show khi performance buffer-pool [{slot[-slot][,...]}]
  3. Show current utilization, 5-minute average utilization, and 5-minute high water mark with date and time of event:
    show khi performance cpu [{slot[-slot][,...]}]
  4. Display memory performance and utilization statistics on the specified slot or all slots:
    show khi performance memory [history | {slot[-slot][,...]}]
  5. Display process performance and utilization statistics on the specified slot or all slots:
    show khi performance process [{slot[-slot][,...]}]
  6. Display thread performance and utilization statistics on the specified slot or all slots or sort the process output:
    show khi performance pthread [{slot[-slot][,...]}]
  7. Display the queue performance and utilization statistics on the switch:
    show khi performance rx-queue
  8. Display internal memory management resource performance and utilization statistics on the specified slot or all slots:
    show khi performance slabinfo [{slot[-slot][,...]}]
  9. Alternatively, you can sort the process and thread output using one of the following commands:
    • show khi performance process sort <process-name | vmsize>
    • show khi performance pthread sort <cpu | thread-name>
Switch:1>show khi performance buffer-pool 1
	Slot:1
      CPP:
         UsedFBuffs: 12
         FreeFBuffs: 3060
         RxQ0FBuffs: 0
         RxQ1FBuffs: 0
         RxQ2FBuffs: 0
         RxQ3FBuffs: 0
         RxQ4FBuffs: 0
         RxQ5FBuffs: 0
         RxQ6FBuffs: 0
         RxQ7FBuffs: 0
         TxQueueFBuffs: 0
         NoFbuff: 0
      Network stack system:
         UsedMbuf: 244
         FreeMbuf: 47606
         SocketMbuf: 19
      Network stack data:
         UsedMbuf: 4
         FreeMbuf: 10748
      Letter API message queue:
         QHigh: 0
         QNormal: 0
         FreeQEntries: 51200
Switch:1>show khi performance cpu 1
    Slot:1
         Current utilization: 6
         5-minute average utilization: 5
         5-minute high water mark: 15 (07/20/23 08:15:22)
Switch:1>show khi performance memory 1
    Slot:1
         Used: 6259174 (KB)
         Free: 1933970 (KB)
         Current utilization: 76 %
         5-minute average utilization: 76 %
         5-minute high water mark: 80 (%)
         10-minute average utilization: 76 %
         10-minute high water mark: 80 (%)
         1-Hour average utilization: 76 %
         1-Hour high water mark: 79 (%)
         1-Day average utilization: 76 %
         1-Month average utilization: 0 %
         1-Year average utilization: 0 %
SMLT socket buffer memory usage 0 KB on 0 blocks
The following example shows partial output for the show khi performance memory history command and depending on the hardware platform, you can also display virtual memory history.
Switch:1>show khi performance memory history
    Slot:1
Values indicate VMSize in KB
Pid    Pname                 5-Min    10-Min   1-Hour   1-Day    1-Month  1-Year
 1733  logger                2        2        2        2        --       --
 1751  namServer             24       24       24       24       --       --
 1752  sockserv              5        5        5        5        --       --
 1754  oom95                 106      106      106      106      --       --
 1755  oom90                 106      106      106      106      --       --
 1756  imgsync.x             25       25       25       25       --       --
 1831  logServer             29       29       29       29       --       --
 1832  trcServer             23       23       23       23       --       --
 1834  oobServer             23       23       23       23       --       --
 1836  nickServer            24       24       24       24       --       --
 1837  nickClient            24       24       24       24       --       --
 2451  dhclient-fan          --       --       --       --       --       --
 1840  hwsServer             29       29       29       29       --       --
 1843  redis-server          20       20       20       19       --       --
 2551  restweb_voss.pyz      33       33       33       32       --       --
 2559  hiveagent             10       10       10       9        --       --
 1844  cbcp-main.x           626      626      623      618      --       --
--More-- (q = quit)
The following example shows partial output for the show khi performance process command.
Switch:1>show khi performance process 1
Slot:1
PID  PPID  PName           VmSize  VmLck   VmRss   VmData  VmStk   VmExe  VmLib
1    0     init            2152    0       1488    168     132     32     1692
2    0     kthreadd        0       0       0       0       0       0      0
3    2     ksoftirqd/0     0       0       0       0       0       0      0
9819 2     kworker/u4:0    0       0       0       0       0       0      0
5    2     kworker/0:0H    0       0       0       0       0       0      0
7    2     rcu_sched       0       0       0       0       0       0      0
8    2     rcu_bh          0       0       0       0       0       0      0
9    2     migration/0     0       0       0       0       0       0      0
10   2     lru-add-drain   0       0       0       0       0       0      0
11   2     cpuhp/0         0       0       0       0       0       0      0
12   2     cpuhp/1         0       0       0       0       0       0      0
13   2     migration/1     0       0       0       0       0       0      0
14   2     ksoftirqd/1     0       0       0       0       0       0      0
15   2     kworker/1:0     0       0       0       0       0       0      0
16   2     kworker/1:0H    0       0       0       0       0       0      0
17   2     kdevtmpfs       0       0       0       0       0       0      0
--More-- (q = quit)
The following example shows partial output for the show khi performance pthread command.
Switch:1>show khi performance pthread 1
 Slot:1
TID   PID   PName           CPU(%) 5MinAvg CPU(%) 5MinHiWater CPU(%(time stamp))
1     1     init             0.0    0.0
2     2     kthreadd         0.0    0.0
3     3     ksoftirqd/0      0.1    0.0
9967  9967  kworker/u4:0     0.0    0.0
5     5     kworker/0:0H     0.0    0.0
10005 2551  restweb_voss.py  0.1    0.2
7     7     rcu_sched        0.0    0.0
8     8     rcu_bh           0.0    0.0
9     9     migration/0      0.0    0.0
10    10    lru-add-drain    0.0    0.0
11    11    cpuhp/0          0.0    0.0
12    12    cpuhp/1          0.0    0.0
13    13    migration/1      0.0    0.0
14    14    ksoftirqd/1      0.0    0.0
15    15    kworker/1:0      0.0    0.0
--More-- (q = quit)
The following example shows output for the show khi performance rx-queue command.
Switch:1>show khi performance rx-queue
CPP COUNTERS
FBUF COUNTERS
InUseFBuffs:                 0
FreeFBuffs:                  3072
Stolen Rx Packets:              0
TxQueueFBuffs:               0
NoFBuffs:                    0
PACKET COUNTERS:
totalCppEnetRxPkts:           0
totalRxPkts:                  0
OamPktsRcvd:                  0
IoPktsRcvd:                   0
IoCopPktsRcvd:                0
PcapPktsRcvd:                 0
Ipv6PktsRcvd:                 2796
RxTestPkts:                   0
RxCpHbPkts:                   0
RxOopPkts:                    0
RxMacMgmtPkts:                0
RxIpfixPkts:                  0
RxOtherPkts:                  0
RxCreditsAdded:               0
MyFramesReceived:             0
totalQueuedPkts:              920329
QueuedOamPkts:                0
QueuedIoPkts:                 0
QueuedIoCopPkts:              0
QueuedTestPkts:               0
QueuedOtherPkts:              0
totalDequeuedPkts:            920329
DequeuedOamPkts:              0
DequeuedIoPkts:               920329
DequeuedIoCopPkts:            0
DequeuedTestPkts:             0
DequeuedOtherPkts:            0
totalPktsProcessed:           920329
OamPktsProcessed:             0
IoPktsProcessed:              920329
IoCopPktsProcessed:           0
OtherPktsProcessed:           0
minPktsRcvdAtOneTime:         0
maxPktsRcvdAtOneTime:         0
numCppInterrupts:             0
numTimesWeReceivedPkts:       0
numTimesTmainProcessedPkts:   816006
TxPktAttempts:                0
TxQueuedPkts:                 0
TxDequeuedPkts:               0
TxPktsOk:                     0
TxTestPkts:                   0
TxIpv6Pkts:                   0
TxIpfixPkts:                  0
TxLsmPktsOk:                  0
TxPktsRecovered:              0
totalLldpPktsRcvd             81683
totalDroppedUpnpFilterPKts    0
avgNumPktsRcvdAtOneTime:      0
avgNumPktsProcessedAtOneTime: 0
PACKET ERROR/DISCARD COUNTERS (non-zero counters only)
DroppedGlbSpbmDisPkts:           3713
DroppedAllRxPkts:                3713
NODE COUNTERS
pRxNodeList count:             0
pRxFreeList count:             0
pRxDirtyList count:            0
OutOfRxNodes count:            0
errorFindingRxBufCount:        0
pTxNodeList count:             0
pTxFreeList  count:            0
pTxDirtyList count:            0
OutOfTxNodes count:            0
errorFindingTxBufCount:        0
CPP BUDGET COUNTERS
cppHardBudgetCount:  2
cppSoftBudgetCount:  2043
cppTicAbsenceTimeCount: 1
cppMimCount: 0
lastIntPid: 29
numSyncRxFrameEvents: 816006
CPP QUEUE STATS:
CPP Priority Queue Num 0  Total Rx Queue Count:     66848
CPP Priority Queue Num 0  Current Rx Queue Count:   0
CPP Priority Queue Num 0  Max Rx Queue Count:       12
CPP Priority Queue Num 1  Total Rx Queue Count:     2286
CPP Priority Queue Num 1  Current Rx Queue Count:   0
CPP Priority Queue Num 1  Max Rx Queue Count:       1
CPP Priority Queue Num 2  Total Rx Queue Count:     66
CPP Priority Queue Num 2  Current Rx Queue Count:   0
CPP Priority Queue Num 2  Max Rx Queue Count:       2
CPP Priority Queue Num 3  Total Rx Queue Count:     0
CPP Priority Queue Num 3  Current Rx Queue Count:   0
CPP Priority Queue Num 3  Max Rx Queue Count:       0
CPP Priority Queue Num 4  Total Rx Queue Count:     13
CPP Priority Queue Num 4  Current Rx Queue Count:   0
CPP Priority Queue Num 4  Max Rx Queue Count:       1
CPP Priority Queue Num 5  Total Rx Queue Count:     33957
CPP Priority Queue Num 5  Current Rx Queue Count:   0
CPP Priority Queue Num 5  Max Rx Queue Count:       277
CPP Priority Queue Num 6  Total Rx Queue Count:     608854
CPP Priority Queue Num 6  Current Rx Queue Count:   0
CPP Priority Queue Num 6  Max Rx Queue Count:       26
CPP Priority Queue Num 7  Total Rx Queue Count:     208305
CPP Priority Queue Num 7  Current Rx Queue Count:   0
CPP Priority Queue Num 7  Max Rx Queue Count:       11
CPP Tx Queue Count:                         0
CPP Tx Max Queue Count:                     0
Processed 10320 pkts over 2505497 milliseconds = 4 pkts/second
The following example shows partial output for the show khi performance slabinfo command.
Switch:1>show khi performance slabinfo
 Slot:1
Name                   Active  Num     Objsize Objper  Pageper Active  Num
                       Objs    Objs            slab    slab    Slabs   Slabs
nf_conntrack           306     306     224     18      1       17      17
jffs2_refblock         32      32      248     16      1       2       2
jffs2_i                20      20      408     20      2       1       1
ip6-frags              0       0       136     30      1       0       0
UDPv6                  60      60      800     20      4       3       3
tw_sock_TCPv6          0       0       184     22      1       0       0
request_sock_TCPv6     0       0       232     17      1       0       0
TCPv6                  40      40      1600    20      8       2       2
sgpool-128             12      12      2560    12      8       1       1
sgpool-64              12      12      1280    12      4       1       1
sgpool-16              12      12      320     12      1       1       1
cfq_queue              23      23      176     23      1       1       1
mqueue_inode_cache     30      30      544     15      2       2       2
nfs_direct_cache       0       0       184     22      1       0       0
nfs_commit_data        18      18      448     18      2       1       1
--More-- (q = quit)
